SSTibet
I have an annoying trembling noise coming from upper right hand side (where tha airbag is located) of my 95 C4 coupe at around idle & slow engine RPMs. The same noise is also audible on bad road conditions (such as gravel, etc). I took it to a shop and the mechanic could not eliminate it. Reason was he was unable to reach the bolts holding the ABS to the dash... How can I learn the procedure to reach around the airbags so that the bolts can be tightened? Remember, I am in Turkey and there is no authorised GM dealer here...
