Q
Quacker
Well you know how it is when your retired with nothing to do so today I flushed the cooling system and filled it will antifreeze, I let it run for a real long time to make sure I had a good mix. When I got into the car I could see that the battery light was on but the volt meter says around 13 volts so I put a volt meter on the battery. With the key off voltage is 12.8 with the engine running it says 14.45
Why does the battery light stay on all the time. It's gets lighter and darker when I put on the lights or heater and run the windows up and down but the voltage is always around 14 volts.
I'm starting to think this is the vet from hell, so I need help again.
