Not sure
Padgett
Adams Wisconsin
1977 stingray
I think I know but..replacing tranny filter,79 filter I pulled out is square the one I got is not..but bolts line up the same way...can I use...
If the holes match up
I believe the OEM filters were metal and the replacement ones are plastic
Sent from my SM-N920P using Tapatalk
Got a pic of both and a part number from the replacement unit?
trans filter
Besides the bolt holes lining up you have to make sure that the outlet from the filter lines up with the fluid port feeding the trans itself.
