entropy454
Im going to purchase a car in the future and was wondering if someone could give me the correct procedure for checking to see if numbers match.
For the engine.
If I understand it correctly, you look at the body tag and compare it to the front passenger side engine pad?
For the 4 speed.
Where do you look for the numbers on a 4 speed?
Could someone give me an example of what the numbers I should expect to see on these locations?
What are other areas for checking for critical numbers correct. For me, engine and transmission would be the most important.
thanks
jim
For the engine.
For the 4 speed.
thanks
jim
