saopm
I’m looking to verify my engine components listed below. I have a 63 roadster which came with a 64 engine. My guess is that the block was replaced and all of the 63 components (heads, intake, etc.) were reused. I am planning on taking the motor out this winter to fix some of the problems with it. The main reason for the engine pull is that one of the valve stems is mashed over so I guess that will require a rebuild on the head. Also the clutch is shot and the oil leak is driving me nuts. If the components are mostly 63, I will rebuild towards a 63 motor. If not I will rebuild towards a 64, 365HP motor. Any help with the numbers would be greatly appreciated. Also, what exactly is the difference between a 63 340hp and a 64 365hp motor? Where do the extra ponies come from?
Thanks,
Tim
Engine Block:
4106305 FI03TRE
Intake Manifold:
3794129
Carburetor:
Carter AFB
3721SR
3851761
DD
Left Head:
8782461
6182
13
Left Exhaust Manifold:
3797901
LH 1
11-18-??
Right Exhaust Manifold:
3797SC2
RH 2 SGC
Left Valve Cover:
3767493
LESTER
http://i19.photobucket.com/albums/b179/saopm/100_1193.jpg
http://i19.photobucket.com/albums/b179/saopm/050409007.jpg
http://i19.photobucket.com/albums/b179/saopm/100_1113.jpg
Thanks,
Tim
Engine Block:
4106305 FI03TRE
Intake Manifold:
3794129
Carburetor:
Carter AFB
3721SR
3851761
DD
Left Head:
8782461
6182
13
3797901
LH 1
11-18-??
3797SC2
RH 2 SGC
Left Valve Cover:
3767493
LESTER
