Obdii - A/c Evap Temp
KOPBET
Tulsey Town
'73 Silver LS4 4 speed
OBDII - A/C Evap Temp
OBDII guys,
This parameter is continuously reading 20 degrees F. regardless of actual air temp.
A. This parameter isn't used in this vehicle. Everything's AOK.
B. This parameter is monitored by the PCM. Something's whacko.
If B, then ?
TIA,
KOPBET.
Hello vette mechs...c4c5?...vettechick?...anybody?
Can someone with 96 and a scan tool please check?
Thanks,
I have the OBDI & II and will be doing a friend of mine's '96 shortly if you can hang on that long. What kind of scanner are you using. I have the Ease software on a laptop.
Thank you, thank you, thank you. :beer
I'm using Auto Tap
