Occasionally wont start - just dead
The73vetteman
Michigan
'73 L48 4spd
I'm looking for advice as to where I should start. Just occasionally I get in, turn the key, and - nothing. No click from the solenoid, nothing. Although the Parking Brake light does come on (I have a 4spd so I use the PB.)
I'll curse once, turn the key again and it'll start up smooth as anything.
I'm guessing its electrical (fairly obviously, I think) but is it a solenoid fault or something in the ignition switch?
All suggestions gratefully received.
'73
had the same typ prob with my 69 . used 1000 cca bat . then cleaned all grounds . as per bat neg to frame .and neg to starter . as well as pos conecton to solinod .found grounds to be dirty and pos conection loose and black at solinod ..after this no more probs .....
Try cursing before the first turn.
Sorry for that. The very first thing I check are the battery connections on both ends... strange things happen when they are even the slight bit loose. Also check the hot wire into the distributor... I had the same symptoms you list and it was as simple as the wire had come somewhat loose... it just clicked into place.
1973 points dist . no hot wire at dist only neg side of coil wire ....
Oops... guess that why it's good to have more than two members in a forum. Thanks... I forgot. :beer
Check the engine ground!
[QUOT E=wallyknoch]Check the engine ground![/QUOTE] is it moving !!!!!!!!!
is it moving !!!!!!!!![/QUOTE]
Small amounts of corrosion at the block can cause this problem. Take it loose and clean it and then reattach back to the engine. :upthumbs As far as moving, I doubt it, it`s not going anywhere, :L.
only haveing fun or pun with the word gound .. . as to say is the earth moving
You have to be careful not to offend anyone from California, {La La Land} the ground out there is always moving. ;LOL
