berry1133@bellsouth.net
Hello all. I have an oil leak on my 1993 LT1. I recently had my intake manifold gasket and oil sending unit replaced, and that all looks good and dry. I'm suspecting it's my oil pan gasket that's leaking from the back of the oil pan. I used brake cleaner to clean all the build up off and notice that it was wet around the back of the pan. After the car had sat for a number of days, oil had started to run on the bottom of the pan. I'm thinking it's the pan gasket because it was wet in that area and, the fact that the oil leak was more obvious after several days of sitting. What are your thoughts and, how difficult is it to change out the oil pan gasket. I noticed that the FSM states that you have to remove the starter, oil filter assembly, and the left catalytic converter. Thanks.
