Question: oil pan
jseremba
Toms River, NJ
1989 Blue Z51 6 spd Manual Transmission
Hello Everybody,
I own a 1984 4 plus 3 Corvette. I just removed the camshaft and found two lobes round. I have the new camshaft in. My question is "should I remove the oil pan and clean it, so that the camshaft fragments do not cause me problems. Can I do the bearings with the motor in the car.
My oil pressure with the car warmed up is always 10/12 psi. I was thinking of not using synthetic oils in the summer. Or should I be replacing the oil pump and other parts.
Thank you
catbert
Moderator
Tobacco Road, NC
Sounds like the motor may be tired. How many miles? If the cam and bearings are shot, I'd take the motor out to do a decent rebuild, but I'm a little conservative that way, and I hate to do major work with the motor in the car.
jseremba
Toms River, NJ
Frankly if I had three grand, I would be rebuilding the motor. I will run it as is for a while and hopefully rebuild it next year.
