meridian6
Have a 92, LT1 (P) with 60K miles. Out of the blue the analog gauge in the cluster pegged on the Hi side. No apparent high pressure symptoms from engine.
After turning off, guage dropped to 80 but as soon as ignition is turned on, it pegs out on HI side of gauge without engine running.
There are Two pressure sending units near rear of engine by center of firewall.
There is a tall (longer) (3 Blade connector) unit that stands almost straight up and a smaller (shorter) ( 1 Blade connector) unit that comes out of the same fitting on a horizontal angle.
WHICH ONE OF THESE is most likely the culprit? Is is it my cluster guage?? HELP-p-p-p-p-p! Thanks.
