Hi
I've been finding that at idle my oil pressure seems a bit low. When at idle the gauge would vary at times between barely above the 0 lbs to up to maybe around 10 or 15 lbs of pressure. When actually driving down the road it would go up to around 60 lbs but drop back to very low pressure at idle when i'm stopped at lights, etc.
I'm also burning through oil fairly quickly in the motor. approx 1 or 1 1/2 quarts every 500 miles or so. it's hard to know just the true milage as my odometer doesn't work but i'm only driving the car locally and haven't been on any long highway cruises lately - only around town so the milage shouldn't be that high between adding oil.
I discussed this with my neighbor who has a '67 BB and does his own work on his car and has been helping me out and he suggesting adding a different weight oil to help my pressure problem. He recommended using a 20W50 weight. He actually uses that weight as his regular, routine oil.
This morning I checked the oil and was down again so I added 1 1/2 quarts of the 20w50 for the first time. immediately my pressure at idle jumped up and it's now sitting at just a bit over 40lbs at idle but if I rev past approx 2500rpm's the pressure jumps to 80lbs or more. The gauge only reads up to 80lbs but now it's pegging the gauge and looks like it's going beyond the 80lbs.
Is this pressure above idle too high and something to be concerned about?
I know too little oil pressure is a major concern, but can you actually get too much pressure in the system also?
