mlm0
I am having a problem of long cranking time on cold start on 89 vette. I have read a large number of articles on how the fuel system and oil system interact on start up. One of the problems I have read about is a bad oil pressure switch sending a low voltage to the ECM and not letting fuel get to the engine. I don't seem to understand the following Is the oil pressure switch attached to the fuel pressure switch and is that location next to the brake booster. Is it one unit or two that I replace Where is the oil sending unit located. Is that the one on the bottom of the block. It seems that when reading about the oil pressure switch and sending unit, some are getting them confused when referring to them by name, which has me really screwed up.. Is there someone out there you can give me the straight info. I think what I need to do, is replace the oil pressure switch and not the sending unit. I have read the FSM, Hanes, and Chilton manuals , but still screwed up.. Boy, do I feel stupid
