Gene's'65
- Joined
- Jan 19, 2012
- Messages
- 6
- Location
- Hixson, TN
- Corvette
- 1965 Nassau Blue Coupe and 1999 Torch Red Hardtop
I removed the old, bad paint using a single edge razor blade on my '65 cpe. I noticed 'wet' spots especially on the front end near the firewall. A local friend, that is quite a perfectionist in the restoration of Corvettes, recommended that I use TSP to absorb the substance. I applied a coat of the TSP and let it set for approx 7 days then rinsed it off. The substance would re-appear after drying out for several hours. I repeated the above steps probably 10 times and thought the substance was out until it was placed in a warm shop and it re-appeared. Ecklers recommended to use 40 grit and take the surface down to the resin. I applied their Gelcoat and in certain areas the wet spot bleed thru. Can anyone offer words of wisdom. I have heard this in not a unique problem in the mid year bodies.
