- Moderator
- #1
- Joined
- Feb 25, 2002
- Messages
- 4,302
- Location
- Cleveland, Ohio
- Corvette
- ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
Was wondering if anyone else has switched up their oil filter to the higher capacity equivalent?
(I use all Mobil-1 oil & filters in my car)
I was kicking around in their website just looking for the sake of looking and I found what seem to be identical filters except that one is a higher capacity (re: more filter surface).
I was originally using the M1-111 since that's the direct cross for the recommended Delco filter, but have since switched to the M1-302. Since the filter hangs vertical off the block, I have no issues with clearance.
And WalMart is still the cheapest I've found when it comes to the buying 5qt bottle of oil. None of the auto parts stores seem to come close when you can only buy individual quarts.
