68Roadster
Where are we at on this problem? Whats the latest?
C'mon, inquiring minds want to know!
Pseudomind said:I looked at another 2002 Corvette with the gas door opened. With the door open the shaft does not protrude out of the actuator any at all when the door is open, so apparently when one closes the door something triggers the shaft to spring out and engaging the plate mounted on the door assembly itself.
Try to envision the image rotated to the left 90 degrees as shown in the diagram
Red is the locking nut which shows in the inside of the diagram
Blue is the actuator body which the looking nut screws onto.
Black is the inside shaft itself. The shaft is cut at taper, tapers toward the front.
With gas door open the shaft is flush with the outer edge of the actuator, apparently when one closes the door the shaft slides out engaging the hole on the plate attached to the gas door.
Pseudomind said:Pardon the lighting and the pictures as I do not have much of a digital camera to talk about. I believe one can get enough information though, if they read the thread above and then look at the photos.
GM Part Number:
10275633 Actuator 12.945, List price $72.53
Hopefully the pictures will be from left to right in order,
1. The actuator end which is inside the fuel door.
2. The protective rubber grommet which sticks up inside the area above the wheel well.
3. The main assembly it self. The left side shows the lanyard connected to the main cable assembly, center section is mounting flange, and the right side is where the electrical conncetor plugs into the main asembly
4. Lanyard
GM Part Number:
4. Lanyard
mqqn said:Hi Folks - I bought a spring assortment at Lowes and repaired mine for $4.90.
http://www.iammoon.com/c5tech/fuel_filler_door.htm
best regards -
mqqn
Pseudomind said:Yes Mqqn very good. The photos really make a difference. I like the link so well I saved it as a document for future reference.
I have a question for you since I currently do not have a cable assembly to look at, how is the plunger held into the plunger guide? Is it held in place by the spring tension, e.g. you push in the guide and turn it locking it into place and then the spring tension holds it there.
The GM fix must be a "sell a part issue," as they (at least for me and the manual shows replacing the complete assembly) never mention anything about disassembling the plunger and replacing the spring. Certainly as one would have to pull the complete assembly anyway to replace, how much longer would it take to just replace the spring The hourly rate would be the same, except GM sales the complete assembly for around $75.00
I had the same problem with my Z06 - but I did not buy the whole actuator.
The problem (at least with mine) is that whenever the car gets wet, at the car wash, in the rain etc, the release plunger guide can fill with water, leaving the spring to rust and deteriorate.
Eventually, the spring will break and or gum up the plunger with rust debris.
If you could buy just the one spring it took, it would be under a buck.
Here are some pics of what I did to my Z06.
best regards -
mqqn
abc said:Strange that you mention water as the day before I rinsed down the car. Which does the whole actuator look like?![]()
mqqn said:Hi abc -
The actuator solenoid unit is under the sail panel beauty cover on the drivers side just behind the driver. You must remove the interior panel to get to it (per the Helms Manual).
If your problem is just a rusty or broken spring, you do not have to even get inside the car - just the drivers side rear wheelwell.
The cable runs from the actuator, forward to the rear of the fender pocket in the fender. The cable is concealed by the inner fender panel.
Pictures of the whole unit are shown in this prior post in this thread by Pseudomind -
http://www.corvetteactioncenter.com/forums/showpost.php?p=682084&postcount=23
best regards -
:cool thanks for the info. The dealership will be doing install today.
Remo said:Once gas prices got over $3.00 per gallon, I had some difficulty opening my gas tank door as well.
Remo:cool
:crazyabc said:
