this is the senario:
car ran pretty good including high rpm's except I knew distributor needed to get rebuilt as the timing curve was WAY off.
Over the winter as I was re-doing the engine and engine bay I had the carb sent out for rebuild.
I also replaced the distributor rotor and cap than ended up sending the distributor out for rebuild and re-curve. The distributor had hi-tension points and as they were only a few months old the guy working on the distributor kept them in. The guy working on my distributor (someone very, very well respected on the NCRS board and who has a Sun Distributor machine for proper re-curving) mentioned he wasn't too sure about the replacement cap and rotor I had just gotten from Paragon and put on and mentioned that if I noticed any high-speed break-up to replace them with different units that he recommended.
When reassembling parts back on the motor I replaced the spark plug wires with new Delco 508N wires as per recommendation from JohnZ and Duke.
Since getting the car running again I haven't driven it too much this season but when I have I've noticed it was breaking up at 4,500 - 5,000 rpms and higher.
I was told it may have been the float levels in the carb being too low and of course I remembers what the distributor guy said about the cap and rotor so today I went to fix the problem.
I re-set the float levels on the carb, and replaced the "new" distributor cap and rotor with the older units that I still had knowing I never had any problem with them and no high rpm break-up.
After setting the carb floats and replacing the rotor and cap I checked the timing and it's dead on at 12* initial, 36* total all in by 3,000 rpm and 52* total w/ vacuum advance.
I also re-checked my fuel mixture settings using a vacuum gauge and it's set based on the highest vacuum readings. I'm getting about 12 in/HG vacuum steady on my L76.
Took the car for a test drive and while it improved somewhat the problem is still there over 5,500 or 6,000 and higher rpm.
I don't like having my motor run that hard so I didn't stay up at that rpm range too long but now I'm wondering if instead of a "break-up" like points floating if instead it's maybe a high-rpm miss.
What is my best course of action to help diagnose and fix this issue.
To summarize:
1. the points are hi-tension and less than 1,000 miles on them
2. dwell is rock steady and timing is dead-on where it should be
3. distrib. cap and rotor are back to the "old" set I was running last year with NO problems like this
4. carb was rebuild and floats are set to the correct level and mixture is set right via a vacuum gauge
5. new spark plug wires (and new spark plugs)
6. new fuel filter
I'm getting a miss or a break-up of some type at high rpms.
Any help is greatly appreciated.
Thanks!
To summarize:
6. new fuel filter
Thanks!
