A
Alfonso Gomez
I have to flush my brake system because the fluid is dark and contaminated with moisture. It is an 87 Coupe without ABS. I know it has moisture because when the engine heats up (190 - 220) the brake pedal goes to the floor and it will not stop. When it cools down, the brakes start working again.
I plan to use DOT 4 fluid sisnce it has a higher boiling point. What worries me is cleaning out all the old fluid and debris inside the brake system.
I plan to open all bleeder valves with small hoses connected to them and pump the brake pedal until all the fluid is collected in jars. Then I will have to put more fluid (cheap DOT 3) and continue to pump the pedal to get all the dirty fluid out.
Is there a solvent I could use to really clean out the system before I use the DOT 4?
S.T.W.
