P/S relay rod replacement
Jeff Farrar
Pittsburgh, PA
67' BB Convertible
I need to replace my P/S relay rod (bent). Once I disconnect it from the idler arm and both tie rod ends, does it just unscrew from the control valve? I'm not at home where I could look it up in service manual. I see were the supply houses sell a larger replacement from the C3's at a much lower cost than an original. I "assume" the fit just fine?
Thanks.
Washington, Michigan
'67 Marina Blue Convertible
Just remove the clamp bolt from the valve where the relay rod attaches, and the relay rod will unscrew (the bolt has to come all the way out due to the flat milled in the threads to clear the bolt). The replacement relay rod that most of the vendors sell is the larger-diameter C3 part, but it will fit a C2 just fine.
