Just replaced the upper spring on the right side parking brake shoes. I noticed that the top of the shoes don't sit against the brake bolt in the middle, are they supposed to? As you can see in this picture, the shoe on the right isn't making contact with the bolt, if I tap on it I can get it closer, then the one on the left doesn't make contact. Does it matter?
Also, I noticed that if I put on the parking brake, then release it, then rotate the rotor backwards, it seems to hang up, until I rotate it forwards, then it's free and stays free.
