Part time turn signal
R
roxeye1
Hey brothers & sisters, I've got a 2000 convertible vette. My turn signal is operating intermittently. It will work just fine for a short period then will suddenly stop and i get nothing. After driving around for awhile it will randomly start working again {for a short period only}. Now for the weird part - If i put my foot on the brake and manually toggle the turn signal lever up and down {for left & right}, the rear lights ONLY will flash in unison with this manual movement of the lever. I was told by part stores & by dealers that this vehicle doesn't have a stand-alone flasher. The only information i could get from them is that it MIGHT be incorporated into something else and to bring it in for analyses. And there's their expensive little secret i'm sure! ;help
5,800 feet above sea level
2006 'Evil Stealth Black' Roadster
Welcome to the CAC, Roxeye!
Take a look at this thread, and see if it helps with your turn signal issues:
CLICK!
:w
-Patrick
R
roxeye1
CLICK!
:w
-Patrick
Hey Patrick, I tried to click onto the thread you offered and got no response. ;shrugThanks for the welcome and any alternative you may have to offer as a resolution to this problem.
That's odd- it opened right up for me when I clicked it.
Well do it without a hyperlink paste:
http://www.corvetteactioncenter.com/forums/showthread.php?t=87919
If it still doesn't work for you, scroll up to the top of the screen. In the navigation bar, pull down the search window and type in "C5 turn signal." It should direct you to a page listing threads in which those words were used. About six threads down from the top, you should see a thread titled "Turn Signal Problems." Click that, and it should direct you to the thread. Hopefully, you'll find some solutions in common.
:w
-Patrick
66vette
Greenville, Ohio
1966 Coupe, 2004 Convertible
You need to replace the Hazard Flasher Switch located in the dash. I had the same problem and that resolved the problem.
R
roxeye1
Thanks so much 66 - Now I have a weekend project. It's been driving me crazy!:beer
Vette_Dreaming
Arvada, CO
Y2K Navy Blue Roadster
This site is just too good, I started having this problem with my 2000 vert just the other day and I was going to do a search to see if anyone else ever had this problem. Now, I don't have to search and I have my answer. Thanks, guys.
mrm1149
North Canton, OH
2000 Pewter coupe
Mine was replaced by GMPP, I've heard some are successful using electrical contact cleaner on the switch.
