pcv valve
It only matters if:
You are going for the factory original look and need everything in the proper place,
or,
You are not able to hook the vacuum line back to the valve. In most cases you can just get a new rubber line that will make the stretch.
Other than than, it does not matter which side of the engine the valve is on as long as it is working.
That' a hell of ride!!!!!!!! is that your car in avatar????? a blowup of it would be real nice!
Torque Shop
Dream Giveaway
