Paul Higg
Today I finally got fed up with the passenger door practically falling off and squeaking all the time. What I did was remove the panel and the weatherstrip and pop riveted three 5/8 strips of aluminum to the door panel. I made sure the rivet heads were under the weatherstrip, I didn't want the rivets hitting the glass. Now that the door was hanging on solid as a rock I took a can of the tool dip you can buy at Home Depot and used a brush and painted all the surfaces where there would be metal to fiberglass and door panel to door contact where it was squeaking. It is liquid rubber and dries quickly. So I put on three coats of this stuff. Then I put it all back together with new lower door panel fasteners and now it is perfect. I can't believe the difference. No more squeaks or panel so loose it is falling off.
I have photos if anyone is interested.
Paul
Paul
