Have read forums about battery drain when Acc is on but I have a new one. I get battery drain in off position!
Have checked switch and verified poles work as expected. Found that mechanical regulator made a click noise when disconnecting battery. Ok reconnected and drove car. Shut off and checked after cool down. Alternator and regulator were quite warm. Disconnected battery. Click again. Installed new solid state regulator. Let sit. No issues with heat.
Ran car and charging system performing as expected. Shut down with no discharge showing on ammeter. No heat at regulator or alternator. Checked next day and both components were warm again. Pulled blue/white connector out of alternator and heat stopped. Checked blue/white poles in alternator and one of them was live.
Is this normal? The ignition is in the off position.
