V
Vette66AirCoupe
Chapter 1
I had some work done on my '66 recently and decided to add the chore of removing the exhaust manifold gaskets that aren't supposed to be there to the short list of stuff that needed to be done. I was warned that the gaskets might be there for a reason but they would try removing them and if there was an exhaust leak I could always put them back on. I also asked for some advice on some engine noise that I can't idnetify.
Chapter 2
The result was that the exhaust was fine without the gaskets and the engine noise was diagnosed as piston slap with the disclaimer that it's really hard to diagnose on a side pipe car. It was always a little louder when cold. Of course this is annoying when you crank it up after a cruise and people get that WTF is that noise look on their faces. I decided to live with it as the fix would lead me down the path of a complete engine rebuild. The repair facility's opinion was that it was not a dangerous situation.
Chapter 3
I backed the '66 out of the garage last Sunday so I could get under the '60 to finish up the clutch replacement job. It was colder than normal, around 16 degrees outside, 45 in the garage as I hadn't fired up the heater yet. The car sat outside for about 4 hours. When I got back into it and started it up there was LOTS of engine noise. I decided to take it for a ride and it became obvious that I had an exhaust leak as well as the engine noise diagnosed as piston slap. Almost as soon as the engine temp got to normal the exhaust leak went away. The piston slap, if that's what it is, remained, though much diminished since the motor was warm. This is a numbers matching coupe, 427/390 with A/C and P/S. The oil level is full and the pressure is fine.
Chapter 4
Lying in bed, daydreaming while watching the Olympics, whatever it is I'm tossing these problems around in my head. Could I have the exhause manifolds decked and solve the leak problem? Might I find out it's not the manifold surface but the heads that are not true? Will the piston slap lead to a major problem that might destroy my numbers matching block and wipe out some real value? Should I just bite the bullet and go for the rebuild, a task I do not want it undertake on my own? What would it cost to do it right? Will I end up with damage to the body?
Chapter 5
Here I am asking a million questions hoping that the sheer volume of this thread doesn't deter you guys from commenting. I'm in the fog and would really appreciate your input.:confused
Chapter 2
Chapter 3
Chapter 4
Chapter 5
