WCLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/21/2005 562648 # B4260 - LOCK, FRONT DOOR - RIGHT - R&R OR REPLACE 11497 miles
Premature wear-out? Assembly issue? Cheap parts?
10/21/2005 562648 # Z7901 - 1-DAY COURTESY TRANSPORTATION 11497 miles
Loaner.
05/06/2005 547522 # C6871 - COVER AND/OR PAD, FRONT SEAT CUSHION - LEFT - R&R OR REPLA 9955 miles
04/14/2005 545391 # C6871 - COVER AND/OR PAD, FRONT SEAT CUSHION - LEFT - R&R OR REPLA 9795 miles
Looks like these two go together on the same side. Bad factory parts that had worn out early... rough on the interior?
07/01/2002 451073 # H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 1435 miles
07/01/2002 451073 G H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 0 miles
04/14/2005 545391 # H0130 - ROTOR ASSEMBLY - REAR - RIGHT - R&R OR REPLACE 9795 miles
10/08/2004 528476 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - R&R OR REPLACE 8818 miles
10/08/2004 528476 # H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 8818 miles
Same parts, same sides. Assembly issue? Maybe owner's actions contributed to the premature failure. Either way... that guy was he** on his brakes! These repairs are the ones that alarm me- they are happening way too often! Just keep an eye on these!
11/18/2004 532334 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 9114 miles
Hit something? Wrong gas additive?
11/18/2004 532334 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 9114 miles
10/08/2004 528476 # C6041 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - BUCKET SEAT - DRIVER 8818 miles
10/08/2004 528476 # C7051 - COVER AND/OR PAD, FRONT SEAT BACK CUSHION - LEFT - R&R OR 8818 miles
Looks like these two go together on the same side. Bad factory parts that had worn out early...11/27/2001 A14617 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Please- don't worry about this one!
Just my read on the car. I think you are okay though. GOOD LUCK!!!
