B
bdisanto
Please see my other posts regarding my problem. My 87 vette will not stay started. It initial problems was that it would not stay started, it would idle rough and stall when I gave it some gas. After all the effort described below I now can get it started, but need to maintain a high idle with the gas pedal for it to stay started. If it stalls it takes forever to get it started. Just to stick it to me a liitle more, last night the starter went, ( I guess from trying to start it so often). I think the starter needed to be replaced any way, every once in a while I would get a nothing when I turned the key, but it always started after that.
I have changed or inspected all vacuum lines, clean throttle body, changed plate gasket, changed fuel filter, good fuel pressure, replaced both MAF relays, MAF sensor ok, checked all plugs & wires,( they were new anyway) New Battery, all fuses ok, new alternator. Any ideas guys, I need the help, the closest shop that I trust is a 60 mile tow?
I noticed a sensor unit that is mounted in the block, drivers side between the 2nd & 3rd spark plugs on that side, it has a green and white wire, the connection is broken, it looks to be a temp or oil unit. What is this? and could that be my problem?
Also, I get no codes ?
Thanks for all the previous replies, please help me, I am going nuts.
