- Joined
- Mar 26, 2002
- Messages
- 812
- Location
- Midlothian, VA
- Corvette
- 1981 white/blue interior automatic
I just filled the 'vette up today with 17 gallons. I calculated the MPG to be 7.74 mi/gal, which is obviously terrible. I do believe a lot can be attributed to driving habits. I rarely drive it, and when I do, it is very short trips around the neighborhood. Perhaps 5 miles at a time, some WOT, usually no higher speeds than 50mph. Still, 7.7 is real low.... I had the spark plugs replaced 3.5 years ago and have put only ~1,000 miles on them since then, so I'd think they could be ruled out.
I also have a slightly rough, low idle that I've been ignoring for years :L 400-450rpm in gear, so it stutters a little. The car used to shake like crazy until I had the EGR valve replaced. Really smoothed out after that... perhaps it's bad again? It was replaced 9/2003, but I've only put 10,000 miles on it since then. I'm under the impression those things clog up all the time. Any thoughts?
Going through my records, it doesn't look like the cap or rotor have been replaced since I've owned it (11/1999). Perhaps start there?
Lastly, is there an idle adjustment screw on the carb, or what? Service manual says the computer does it, the internet tells me that's wrong. If there is an idle screw, where is it? Thanks....
-Tatortot
-Tatortot
