Another nice day, more wrenching..... Here's what I've found so far:
1. Dwell meter stays at 2.9 degrees, BUT when the engine runs rough and drops by ~100 rpm, it spikes to ~30 degrees. It jumps all around, up to 36, down to 27. Then, when the engine smooths out, back to a steady 2.9 degrees.
2. There is no vacuum going to the EGR valve. If I trace the vac line down stream, it plugs into the front of the carb. When I remove the line, there is no suction coming out of the carb. It is the solid purple line coming off the EGR solenoid to the front of the carb in the attached picture of the emissions label. Should I be feeling vacuum here?
Any thoughts on what's going on here?
Gerry, I did spray WD-40 around the valve covers, and carb base, and didn't detect any change. I wimped out a bit as I didn't want to spray the stuff where I couldn't reach it.
-Tatortot
tattor,
The EGR valve is inop at idle and at deceleration (the computer detects these engine regimes, and turns-on/off, vacuum to the EGR through the solenoid), so don't let that detract you.
Honestly, it is a pain, but it will be worth it when your Vette starts running great. Vacuum being utilized/bled/leaked at idle causes all kinds maladies.
1) Check all your emission's hoses to make sure they are routed to where they should be. That emissions label is great for that.
2) with a hand-operated vacuum pump, disconnect the hose at the EGR and connect the hose from the vacuum pump. What you are doing is checking for movement of the diaphragm. This movement represents the movement of the needle valve inside, and it will show if it stuck open (it is spring-operated closed). It being stuck open, it would explain the rough operation at idle.
3) Next, if the EGR checked good, then check that the gasket is in good condition. Check that the bolts are not loose. If everything is fine, then let's move on to the next set of checks.
4) use vacuum pump to check the thermal vacuum switches (TVS). If they are stuck open and the engine is cold, you will not be able to build a vacuum signal on the pump's gauge. At this time, it really does not matter which port on the TVS to which you hook-up the vacuum pump because we are checking whether it is stuck open or not. To determine that the TVS is working correctly, the vacuum pump should build-up a vacuum signal on the gauge with the engine cold. If it is not, then it means that they are bleeding vacuum signal at a time when is not needed or it is detrimental to engine operation.
Note: Should the TVS be stuck closed when engine is warm, this would not necessarily explain the rough operation at idle. It would most likely explain emissions test failure.
5) prepare for engine start. With a couple of segments of rubber tubing the correct size and matching vacuum T-fitting (auto Parts store's "HELP!" rack carries a sorted kit. What you what to do is to reconnect the EGR's hose at the EGR and disconnect the same hose at the solenoid (the other end). At the solenoid end, install a short segment of hose to the solenoid, a similar diameter size plastic T fitting, and another small segment of hose to the opposite plastic fitting tube. Then, connect the remaining end on plastic fitting to the vacuum pump hose or vacuum gauge. In effect, this will help you tap into the vacuum signal that may be present at the EGR valve hose, in order to determine if there is a vacuum signal present.
Note: There is supposed to be a vacuum signal at the opposite side of the solenoid. The computer determines when the solenoid is activated to apply vacuum to EGR valve. By patching the vacuum pump or vacuum gauge like I explained above, will help determine if the solenoid failed and is allowing vacuum signal to the EGR during engine start or engine at idle speed.
6) Start engine and while it warm's up, check the vacuum gauge. There should be no vacuum signal when engine is warm.
[i'll start my next posting at step "7)" to continue with troubleshooting.]
