S
STREETRODS
HI-i have a 79 vette we just bought. never had one before. it is really hard to start and when idling in gear will load up and die-then is flooded and harder to start.
the carb-quadrajet- has been rebuilt and mech. tried two other carbs on the car and same problem. the vacuum at idle is about 16, and in gear at idle about 11. the dist. shaft is new and the mech. advance rebuilt. the fuel pressure is a bit high with new fuel pump on it. plan on putting a pres. regulator on.
could my problem be timing chain? the engine has never been apart-71,000 miles. and compression is 150lbs. give or take 5 lbs.
vacuum advance is hooked to the no vac. at idle side of carb.
Is the vacuumn headlights possibly the culprit?
any ideas would be appreciated.
