Mike2001
Could storing the key fob within ten feet of the car cause a drain on the car’s battery?
Leave the keys in the ign to keep the alarm shut off and get a battery tender.Could storing the key fob within ten feet of the car cause a drain on the car’s battery?
HI there,
Yes, it most certainly can.
Allthebest, c4c5
"Leave the keys in the ign?" You obviously don't have a C6, do you?:eyeroleLeave the keys in the ign to keep the alarm shut off and get a battery tender.
Works for me
And you should simply disconnect the negative battery cable for extended storage and NOT use a battery charger.
Allthebest,
Hi there,
No, its better to put the key fob in the house, away from the car as far as possible.
Allthebest,
Yes, I do.
On all vehicles stored over 2 weeks without driving.
Allthebest, :bash
Yes the ECM will have to relearn parameters but it don't take it that long,If the check engine light is working and not on, and the ECM will communicate with State Inspection computer,It will pass NC Emissions Inspection!!!C4C5,
About disconnecting the negative cable, doesn't this mean you have to re-establish the drive cycle each and every time you reconnect the battery. Which would also mean that in states like NC that use the OBD II check for vehicle inspection you need to drive the car for a few days prior to the inspection to assure the drive cycle is re-established or you fail the inspection.
Right or wrong?
MMM
I drive them to Black Mountain (Over the Big Hill!!) 8 mi on I-40,never had one not pass!Junk,
The last time I had to reset the drive cycle monitors it took about 100 miles of driving. I initially tried using the GM procedure to reset the drive cycle, but had a hard time following in on the densely traveled public roads in this part of the state. So I drove it for two days and checked the monitor(s) status with an OBD II Code. Nothing was flashing anymore so it passed. Previously it failed after driving it for only 25 miles after reconnecting the battery. When I checked the ECM with the code reader it showed two monitors (and I forget which ones) not yet reset (flashing).
My point is do not disconnect the battery, immediately drive it to be inspected and expect it to pass.
Mike
