L
lancewest
If it wasn't for bad luck....I wouldn't have any luck at all.
For weeks I've been dealing with a fast idle, 1100 RPM, changed the IAC valve, wiring, ECM etc; also checked for vacuum leaks, finally I'm getting a loud hiss when the brakes are applied, sound is quite loud under the dash. So any similar problems experienced will be appreciated.....possibly my check valve may be the problem, one's been ordered and will arrive in two days. What are the odd's of it being something worst, like the booster drum itself?
