Power seat adjusters
Hrtbeat1
MS Gulf Coast
'90 coupe (gone) '96 CE LT4 Z51
Hey can anyone help? I just bought a 90 coupe with sport seats. The guy I bought it from said the drivers seat adjusters didn't work. I got to messing around under the seat and everything was disconnected. I reconnected everything now it all works except RETRACTING. I got it forward but now it wont go back. I think it may be the switch (since the motor moved forward). Does anyone know of a bypass or jumper to make the seats go back?
This will be trickey
If you pull the pad ( seat bottom ) up there will be a connector..
pins A( purple ) and B ( Black ) are on the motor for the seat back angle adjustment.
the wire on the other side of the connector is orange( to purple ) & black ( to black )
You need to feed 12 volts directly to the PURPLE & BLACK.. and the polarity of the power feed will move the seat back angle up or down ( based on motor rotation ).
Vig!
Thanks .... I found a different answer ... after checking voltage at the connector ... thru the various switch positions. I found that the red/grn wire all the way to the motor is forward .... the yellow/grn wire is reverse .... its definately the switch cause switching the wires and running the switch (in forward) I got the seat to fully retract.
Note: the voltages are very small around 1VDC but a test light will help identify which switch position is powered.
Oh I misunderstood
Your talking about the MAIN motor track
red/green is 1 pole of the motor and yel/green is the other pole
the switch reverses polarity to the motor feed
ergo fwd & reverse.
You probably measured that wire to ground..
OOPS
Vig!
