Gobbles
Not sure if mine is working or not. I talked to the guy at Advanced auto, said if the fluid is not flowing, then its not working. Checked, Fluid not flowing. Is he right? Thanks for the help.
P/S pumps on the C4 are notoriously weak (under extreame use, like track days) I've been through two, they no longer make new ones and rebuilds are a crap shoot (had one bad out of the box). I'm not sure how you'd tell if the fluid is "flowing" without removing the resivoir return line. Is steering hard; stiff spots when turning? Is there noise when turning wheel? Fluid leaks? Could also be the rack.
