OSU-VETTE
Drivers side window has stopped going down, goes up, seems to be a little lower in the back vs the front, but when I push a little down on it while pushing the down window switch, it goes down, but stops with 2 inches exposed - 1 inch in the rear, 2 in the front. I have not tried to put it all the way up yet, concerned it could fall out, or worse.
I had an older truck that had a window jump it's track, but that would not move at all, this one appears to be off a little. I have not replaced anything in the door, nor the switches, the passenger side works fine, as did the drivers until today. Could it be the infamous ribbon cable? Any help is greatly appreciated.
