- Thread starter
- Admin
- #21
Actually, I think it's a pretty fair comparison. We're talking about basic engine design, not the length of time in between two different engines. Time is not that relevant in this discussion.Brett said:People are constantly comparing the LT5 to the LS6 lately in these DOHC vs. pushrod debates.
The common comment is "The LS6 produces the same horsepower as the LT5 with a far more simple design for much cheaper!!!"
Well, I have to say that is not a fair comparison......at all. These engines are TEN YEARS apart, and they put out identical horsepower! Give the LT5 TEN YEARS of developement, and then lets see what kind of output it has! In that respect, I don't find the LS6 very impressive. In fact, a common comment that you hear is "Now if only we could get the LT5 in the Z06's body........" In the last 10 years, Corvette has not gained much ground, and arguably NONE.... Although, admittedly, the ZR-1 did set the bar pretty darn high.
Yes, the transition to DOHC will be costly--but any change is going to be at first. Once it becomes the norm, it's not going to be so "expensive". I don't think technology should stop just because Corvette guys are obviously more familiar with and only know how to fix their pushrod engines. If Corvette is going to evolve and compete on a global market, we need to be a bit broader minded and let go of some history and our childhood biases.......let history be exactly that---history. Pushrod engines are not Corvette's tradition. Corvette's tradition is CUTTING EDGE TECHNOLOGY.
I think this 3 valve design is a step in the right direction.
Brett
If the LT5 and DOHC architecture is so great, I would have to ask, why did Mosler decide to use an LS6 engine for its MT900 and didn't bother to use a DOHC engine like the Northstar?
There is no doubt that the DOHC design is a good design - I believe Ferrari is using them in their Modena models. However, if you can build a reliable, fuel efficient, low weight, simpler engine that meets emissions specifications and can very easily be modified to yield more power, why would you want to mess around with a more intricate engine with more moving parts?
Take a look at how much it costs to modify an LT5 engine to yield more power, vs. what it costs to modify an LS1/LS6 engine to do the same.
