BarryK said:Our Border Collie's head reads 83* but his back is only 79*![]()
Can you perform a rectal with one of those?
67HEAVEN said:Can you perform a rectal with one of those?![]()
Geek's 65 said:So you guys going to Napa and AutoZone to get a fan clutch for @ $40 - got a part number? I need one, called the Napa and the Zone only to get a "good luck finding that".
Geek
BarryK said:the NAPA part # is 273370. It was $46.00
it's made by Hayden
might not be as good as the Eaton part but if it works I'll be happy and it's a lot less money
Viet Nam Vett said:Well ..ithe importnt thing here is ...It works..... Now drive it to Carlisle....:L
BarryK said:Geek
glad it worked out. Paul (Subfixer) VERY GENEROUSLY offered to help me change mine out while we are at Carlisle so I'm bringing mine with me and some various tools and we will see if that helps make a difference on my car also.
IH2LOSE said:Barry
Have Paul only watch this is definatley a job you can do yourself. I dont know if you own a set yet but this is definatley a job for some ratcheting box wrenches.
Subfixer said:Call me old fashioned if you like, but I have not found any need for those ratcheting wrenches on these old cars. Although I will eventually get a set to work on some of the newer cars out there (the wife's BMW comes to mind), those wrenches weren't even invented back when our old C2's were built and no one seemed to have a problem then.
I find that using the old tools is just as much a Zen experience as working on my old car. Very relaxing.
ctjackster said:One example: removing the radiator fan shroud - at least one of those bolts on the p-side (all of which come in from the front) is blocked by the horn I think - the ratcheting box wrench is the only way to get it off, reasonably (aside from removing the grill and removing the horn, I guess
