Greetings,
I'm trying to gravity bleed all the fluid out of a 1994 using this method:
"Bleeding the Clutch Hydraulic System -
One method for bleeding this system is to let fluid simply run through the system until clean fluid comes out. Close the bleeder screw , climb into the car and press down on the clutch pedal about fifty times. Then go back under the car and allow a little more fluid out one last time."
The problem is very little fluid has come out and the master cylinder is still full. Even with the bleeder screw out no fluid flows. I was able to spurt out some by pumping the clutch but now the clutch is floppy and the master cylinder reservoir is still full. I do not have any vacuum tools etc. Any ideas? Thank you.
