Project Anti-Ken-A Very Low Budget 350 build
Status
Not open for further replies.
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
While I was working on my other project, a mild custom '69 C10 Stepside, I decided to pull the distributor and intake so I could more easily paint the firewall back to the original yellow. I bought this project as a basket case but I do remember this engine running when It was in the donor truck.
I soon found out that I could not turn the engine far enough to line up the timing marks. After trying various things and pulling the distributor and intake it still hit a stopping point. I pulled the valve covers and bounced all of the valves with a hammer. No stuck valves so off came the heads. #3 and #6 cylinders had a 2" water line in them from water coming in the open intake valves. Obviously someone (brother in law that I bought it from) left it out in the rain with the air cleaner off. The cylinder walls were heavily rusted since the last time this engine would have been ouside was at least 10 years ago. That water sat and rusted until it was gone then his damp shop helped it along.
It was just a 2 bolt out of a '72 Monte with who knows how many miles on it before it was put in the donor truck. Not worth spending money boring. Anyway, now I get to build an engine. The problem is that I don't have any budget for a big time engine project like Ken's. Hense the title Anti-Ken.
The goal here will be to put together a good running 350 for under $500. Nuts you say? Maybe, but in this case I don't require NASCAR tolerances or high tech parts. I need an engine that will perform to new car specs for general transportation but will get up and go when I need to merge or get out in traffic. I will try to follow a course of action that others can follow to freshen up their basic 350s in their older cruiser Corvettes that won't be seeing any severe duty use.
Things I don't need for this engine are forged pistons, cast are just fine; forged crank, alloy heads or heads with high rpm potential, high dollor rods, roller anything, super balanced job, or hundreds of dollors worth of machine work that only a all out racing engine can benefit from.
As you can tell I believe that most street or street/strip engines are overbuilt. If you consider that factory specs engines have went zillions of miles and been exposed to untold abuse and usually lived to talk about it you underestand what I mean.
Here's what I come up with to begin this project after taking apart the bad engine and cruising the shop for parts:
1) '79 Z28 4 bolt block. Std. bore with no appearant wear.
a warranty block removed when almost new. The problem wasn't the block. All it needs is a clean up honing.
2) The crank out of the bad engine is std., std. and only needs a light polishing. Thrust plate is as new and so is the snout. Mics round and std. throughout.
3) The heads off of the bad engine are new enough to have hard seats and have never been ground before. They will be fine for a low to mid range engine after rebuilt.
4) Flex plate is as new and balancer appears ok.
5) Old rods mic near perfect so I'll have them magged and put on the new pistons with new rod bolts.
6) I have an Offy manifold and '66 Holley off of a Chevelle to go on the finished engine.
7) I have iron exhaust manifolds and a complete new chambered exhaust system.
8) The single point distributor needs new bushings and shimmed but I may go electronic
Things I need are pistons, rings, bearings, gaskets, timing set, cam and lifters, valve springs, push rods and oil pump. Other things may pop up.
Well this is where I'll start and I'll post progress reports as it goes. Comments are welcome and yes I do expect to catch flack for the things I won't be doing along the way. Some will probably say that all I need is a dirt garage floor to make this build perfect.
Wish me luck.
Tom
The other side.
Sounds like a fun project! You can paint it up pretty before you put it back in, and it'll probably only run for 100,000 miles! :Steer
Hey, it's only a little rusty Tom. :L
"Project: Anti-Ken" eh? :eyerole It ain't like I got a lotta money, I'm just gonna spend what I do have before I die. ;LOL
_ken :w
That's what I think John. My bro in law rebuilt this engine with a can of Chevy orange and chrome accessories. Didn't work too well as the timing gear only had about 20% of the nylon left on it. :eyerole I found pieces everywhere. I'm amazed that it hadn't jumped time yet. I could almost take the chain off without removing the cam gear. :L
Tom
Tom , I think you should use that Smoky Yunick manifold hanging on the wall , just because it's so unique . Cliff
Hello Tom,
I have a new, in the package Cloyes Heavy Duty Double Roller Timing Gear Speed Set I want to contribute. I was going to use it on a engine project last Spring but decided to go with a crate engine instead.
Too much stuff in the garage and this will be an early start to spring cleaning. If your block turns out to be junk I have a 3970010 based long block that needs a rebuild we can work something out on. Theres also a 454 long block out of a Cigarette boat back there.
Send me your address via e-mail and I'll send the Timing Gear Set via UPS.
Eugene
Cliff If I used that unique Yunick Smokey Ram I 'm affraid I would have to build a liittle more engine. They restored one of these manifolds in one of the magazines a couple months ago. Then they put it on a dyno engine and it made some fantastic numbers. Smokey always said it was the strongest mid range manifold you could use.
Tom
I agree with you Ken. I cant spend it when I am dead, so I plan on spending prior to that. :D
Eugene,
Thanks for the offer of the timing set. That would be perfect and better than a standard OEM. I'll email you. I think I should give you someting for it. We'll work it out.
The block I'm using is a 3970010 and as I said it was nearly new when I got it. I oiled it up and put it in an engine crate about 20 some years ago. It was really clean in and out until last winter. The crate sat behind my table saw all winter while I was finishing the inside of the garage. Yea I know...I could have moved it. Isn't saw dust a protectorant?
Here are a few pics of the subject of this experiment.
The block out of it's 20+ year cacoon.
The main bearing bores are perfectly in alignment. I torqued the caps and checked around the circumference at each 90 degree intervals with the straight edge and feeler guages.
Using a snap guage you can feel if the main bearing bores are out of round. All is good.
Smokey said once to lay your straight edge on the deck. Shine a bright light on the back side and look for any light between the straight edge and the deck. No light showing, no low areas or uneven surfaces. No decking required. Or something like that. I check front and rear and across the bores. Also several places side to side and diagonal.
Both decks are flat as Mother Earth before Columbus. I guess we have a block. Now I need to clean that pig up.
Tom,
I hope you keep posting pictures as your engine build moves forward. Looking at them will give me something to do while waiting for spring.
There's no need to pay anything for the Timing Gear set.
Well...... perhaps you can buy me a drink if our paths ever cross.
Eugene
Tom, nice to see you got the hang of the camera, now we gotta get you some storage space so we can view the pictures without having to click attachments. :L
_ken :w
I know Ken. Maybe I'll get around to that this week since I'll be posting a lot of pics. I do tend to put things off a little. :L
Tom
Geez, that reminds me; I've got some pictures of my work today, waiting to be cleaned-up. They've been sitting open since about five o'oclock because I was waiting for the sun to go down so I could see them clearly on the screen. :L
_ken :w
Here is the intake that Cliff (DkBG) would like me to use. It does look cool but I fear it's a bit much for a mild engine. It doesn't have exhaust heat for those cold mornings and would require at least a double pumper because of the large plenum. I'd also need serious heads and cam and higher compression. I'll build an engine just for this manifold someday Cliff.
Edelbrock SY1 Smokey Ram designed by Smokey Yunick
Sorry. the next few picture were lost with the old member's gallery. I can repost them if anyone wants to see them.
Ken,
Since I have this picture thing down I'll add a couple more. This is the intake I'll use. It's a single plane Offy 360 degree but Offenhauser says it's good off idle to 5500 rpm. It has carb heat and a cast in boss for a '60s style GM choke thermostat that will hook right up to the Chevy Holley I have. Since I have the manifold I'll give it a try. I can always change it later if it's dead on the bottom end.
Status
