Ken
Gone but not forgotten
All at about a tenth of the cost of mine.
It should move the old stepside along pretty well but mine won't do what yours will. :eekKen said:All at about a tenth of the cost of mine.
Tom:Tom Bryant said:DONE. $1249.91Attached is the complete summary of the build for your viewing pleasure.
My bracket sandwiches between back of bare pump and front of driver side head ... bracket bolts to head's accessory bracket holes with countersinks & pump is through-bolted into bracket.Tom Bryant said:Jack,Does yours bolt to the front?
Yes ... you either get a race pump (such as Sweet) or take a newer (smaller) style pump & toss OE tank & plumb it for AN fittings & swap serp pulley for V. The Sweet pump at link above is the newer smaller OE pump. The pump like what's in your later C3 vette is the older larger pump and will NOT bolt up to my race bracket ... even if reservoir removed it will not bolt up ... must use later smaller pump. I dunno what year they started but plenty in junkyards ... I think my 89 Ciera had late small pump ... saw one on 93 caddy last week ... AFAIK all had plastic tanks & serpentine pulleys.Tom Bryant said:Jack,Also can you run a stock p/s pump with a remote reservoir?
I think you're onto it Tom. Maybe if you use a double groove crank pulley ... & use the forward groove to drive the psp ... maybe you'd have it licked. John's right, as my 97 Sonoma (S10) has the same small psp we're referring to ... same type bracket setup as my spare I offer. Oh yea!, John's GS setup sure looks sweet ... lotsa supertrucks around here run Appleton rack too ... very stout piece.Tom Bryant said:I have another pump with a single groove pulley and with it mounted on the same bracket it is a whole groove out to far. Maybe the problem is the pulley offset.
