I talked to my machine shop guy today and he said the valves were showing wear on the stems and the exhaust guides were a little loose. They magged ok and the exhaust seats are already hardened type. We decided to go with new stock type valves since it is just a mild engine and upgrade the springs and trash the rotators. They have a better spring that works well with mild cams and won't pull the studs if I run it out to 6000 or so in a moment of exuberance.
Me?
We also talked CR and head gaskets. We might have to do a clean-up cut to set CR where I want it. He will be calling me today or tomorrow, I hope, with a quote. Then I'll pick them up so I can do the port matching and clean up the bowl areas before the machine work begins.
I have a feeling that I'll be in the 60-75% area of the price of a set of new Vortec heads. That's close enough to make me think I should just go with new heads BUT.....
1) I would need a new intake. Vortec intakes. either from Edelbrock or GM are nearly twice what a basic Performer manifold runs, plus I already have that Offenhauser.
2) I can't use the GM divorced type choke on that OEM Holley I have with a new intake so why mess with the old Holley. New intake plus new carb = about $500.
3) I remember Hot Rod said there was a head part number released for Vortecs drilled for both type manifolds. Sounded like just the ticket until I read that you must use a raised runner or Vortec type intake. Older intakes will not have enough lip at the top of the intake runner to provide enough gasket sealing surface for street use. In other words, a vacuum leak waiting to happen.
So just buying the Vortec heads is only part of the cost of the change-over. For what I'm doing I think I'll stick with my old heads unless the quote is way too high.
Tom
