BLACK MOON
I set the body back on this morning and as suspected the Keisler transmission contacts the tunnel. Specifically, I found that it hits the dip in the tumel that accomidates the brackets for the console trim. This occurs only on the right side at the rear bracket. I ground this bump off and will reglass from the interior of the car. After the grind, the transmission was still too close to the floor for me so I am raising the body with 3/8" rubber shims. This gives plenty of room at the top of the trans. I'm going to see what other problems adding the shims causes before bolting all the connections.
