Beware and do your research. I bought a 98 with same problem and naively thought it would be a simple fix. Short story - abs pump, module, and wiring plug had to be replaced at a cost of
$1,600 with used parts. The car only had 16,000 miles on it and was in pristine condition otherwise. Get a reputable mechanic to check it out
