Dave Carney
The dealer installed the new BCM, programmed it, and cold started the car this morning as a test. They said it started fine. I picked it up this evening. Is it fixed? I don't know, it won't be cold enough for me to test it again for a while. It was cold though when they tested it.
But, check this out. On the service order receipt, they reference code B1440 (as the cause behind my SVS on the DIC when it no-cranked) and they call this code "Fog Lamp Open" circuit. But according to my Helms and everything else I can find, this DTC is actually a Power Mode Master Input Circuits Mismatch. According to the Helms it's basically a communications mismatch between the BCM and the RCDLR. They list a procedure for testing the wires in the harness at the ignition switch ! (for specified resistance, voltage) and if the wires test ok, they say to replace the ignition switch. This makes a lot of sense. Simple. And cheap if it's only the switch, $25. I could do this test myself and I will if it no cranks again.
