Putting a 1990 Corvette L-98 into my Classic 1972 Blazer
72Blazerod
Vancouver, Canada
1972 Sunflower Yellow Coupe (Bone Stock)
Hi guys,
I am a newbie but I have loved Vettes since I can remember. I want to get a 1972 Corvette to go with my 1972 Blazer, but that's besides the point. I need a list of items, names and prices for a few things to get this 1990 L-98 I have in my garage into my 1972 Blazer.
Here is the list I have complied so far but I would like to know what I am missing and where I can get a good deal on these parts:
New throttle cable
Vehicle Speed Sensor (JagsThatRun)
External fuel pump (eventually a new tank, but not necessary)
New fan (opposite flow water pump)
New radiator hoses/fittings.
New fuel return line.
New air filter and fittings to direct away from radiator
Is there any thing that I am missing? Where can I get this stuff? Do you have any suggestions as to name brands or part numbers?
Thanks guys,
Rod
jsinga
Savannah, GA, USA
87 Silver Coupe Way over 200k miles
I think you can do it easier than using the electronics from the vette.
I would see if I could use the computer from the Ramjet 350 crate engine. It is a one wire connection. The computer and everything are located on the engine and it only needs the hi pressure fuel and 12v. It was designed for a boat.
Otherwise get the book on installing a TPI from JTR
JS
S
Shadowing1985v
to bad u have a L98 and not a LT1 in your garage, hehe
L98's are 230 hores to where LT1's are 300
but then again u have a 1990 one so it may have like 260 hp on it or 240
69MyWay
Auburndale, Florida
1969 Killer Shark
72Blazerod said:
New throttle cable
Thanks guys,
Rod
Throttle cable---Try a 3rd gen camaro cable from the bone yard. It should be long enough for the truck.
The speed sensor will only be needed depending on what computer/harness/trans/speedo gauges you are running. I suggest you get a complete Painless Wire Harness for the L98 including the appropriate chip. THey will inform you of what speed sensor if any you need to run.
You can get a high pressure pump from almost anywhere now. Just call summit racing 1-800-230-3030 and tell them whay you have and get what you need.
Go with an electric fan on the radiator--quieter, less energy drain, and makes the engine look cool. You can go to the bone yard, or order one from Summit while getting the wire harness/pump/chip
You will just have to measure and fit the radiator lines one at a time. I hope you have a Napa or such near by.
The return fuel line can be had from Napa for about $3 a foot, or from Summit Racing when you get the other. High pressure MPI rubber fuel line is just fine. There is a blue colored line that holds 250 psi. I have that included with my EFI kit from Edelbrock. Must hydraulic supply line companies will sell it to you.
Look at the F-body, most likely a Firebird for the front air intake tube in a 90 degree. EVen the later model LT1 will fit. From there you will just need straight tube and the cone air filter. Again, check with Summit, as they have some ram air/cold air induction tubes and hoses for the F-body that should drop right into the truck on the TPI.
Good luck! Welcome to CAC. I might move this thread over to "other cars" later on to get more exposure there. We will see what Ken and Jay think as well.
Redbob
Cross Roads, Texas, U.S.
'89 dk red coupe
RE: L-98 vs LT-1
He's putting the engine in a truck; look at the difference between the L-98 and LT-1 torque curves, and you can see that the L-98 looks like it was designed as a truck engine!
- R
Redbob
'89 dk red coupe
And regarding electric fans for cooling:
Again, it's a truck. Electric fans that won't cool a 3400 lb Corvette surely won't cool a 5400 lb truck!
Unless "looking" cool has some thermodynamic value! :)
