dshanks
Hi. Im currently working on the timing and vacuum, and I was wondering if I could get some assistance making all the correct connections to my new Quadrajet that I bought from Carburator Dr out of Canada...
The carb is not the same model at the one that came on my 71 4speed. It has an electric choke, and there are more vacuum ports than what mine had.
Ive tried to take detailed photos of the connections in question here.
these first 2 pics are of the front of the carb. I have labeled each port, there are 2 views with the same labelling.
Connection 1 is currently blocked off. Connection 2 is currently going to the PCV valve. Connection 4 is going to the Vacuum can (not sure exactly what it does) in the left fender.
I have been experimenting with connections 3 and 5 for use with the vacuum advance. I have a feeling this is what Ive read so many threads about "the big debate"?? But I really have no idea...
There is also a hose that you can see that goes from one fitting to another. The carb came like that and I haven't touched it. I figured it was there for a reason.
Also, can someone explain the different adjustment screws that can be seen on the bottom of the carb? I know the idle on the throttle arm, thats it...
Here is the fitting on the manifold, it goes to a splitter, then to the firewall and to the top fitting in the vacuum can. The fitting here on the back of the carb goes straight to the power brake booster.
Here is the electrical connection that went to the carb before
And heres the connection on the new carb
As always, thanks for all your help! If you have questions let me know!
Derrick
Derrick
