Question about a '75 Clutch
I
id008
Hi, I'm new here in this forum and I was hoping that someone here could help me out. I'm going to replace the clutch in a '75
conv. and I don't know how to find out how many splines are on the clutch. I know that I have a Saginaw 4-speed, but I don't know where to find the info I need. Any help would be greatly appreciated. Thanks.
help
You can get all the info you need here
http://www.sallee-chevrolet.com/BorgWarner/bwt56.html
or here
Cangro Transmission of N.J., 295 Crooks Ave., Clifton, N.J. 07011-1615 (973) 772-7662 or 1-800-4CANGRO; FAX (973)772-9446
10-23 Jackson Ave., Long Island City, NY 11101-5884 (718) 937-8011 Fax (718) 937-8916
Cangro@ix.netcom.com
or here
Long Island Transmission, 2160 Route 111, P.O. Box 5083, Hauppauge, N.Y. 11788-2900 (631) 582-9192 Fax (631) 582-9277
'75 trans
The '75 came with either a close ratio or a wide ratio trans. They were both Warner items. If you are sure you have a Saginaw in your car you will have to remove it to see what the splines are. Saginaws were not used in Corvettes so somebody would have had to change it. Both Warner trans use the same clutch disc but I can't find a reference right off as to spline count. GMPD didn't list spline count in the books since both trans used the same disc and it didn't matter.
I would speculate that since they call the Warner a HD aluminum case trans that it has 26 splines.
Tom
Thanks again for the info, it is very much appreciated.
