H
Hotred94
I was reading what Eagle was saying about using heat duct insulation to cool and quite things down in his vette. My Flowmaster 40 can be a bit intense so I ran right down to Home Depot and got some. I pulled the carpet out of the rear deck and found where some previous work had removed some insulation around the ASR stuff and not replaced. I filled it in.
Since I had to remove the speaker grill, I decided to check the speaker and pulled it out. I found that the bass reflex area has no insulation. This area is right above the mufflers, and the noise just comes right through the bass porting tube, so I lined it with duct insulation and filled it with fiberglass. That shouldn't hurt the speaker sound any. I also found there is no insulation in the middle section of the two little hatch doors.
Now I've been working on the center console area, but I'm having trouble getting the upper center piece out. I've undone all the screws I can find including the ones by the hatch release button and the screw in the cup holder. The piece that the shifter goes through can be lifed at the rear about two inches, but the front of this piece seems to be screwed into something still, maybe the piece with the radio. I can't find how to undo it, can someone help me out. I have a 94 auto.
