going to pull the intake and valve covers off next week possibly to clean them and spray them with the Alumi Blast paint.
i'll need new gaskets for both.
I think I read that on the intake manifold that there are just side gaskets and to use silicone for the front and rear of the intake during reinstall.
1. Is Permatex Ultra Copper good to use for the front and rear of the intake?
2. any particular type of gasket recommended for the intake sides? brand and part numbers would be great if anyone has specifics.
3. I've noticed in threads that people recommend washers under the bolt heads on the intake but mine doesn't have them. Is this something I should add? If so, anyone know the proper size?
4. when reinstalling should I use a thread sealer on the intake bolts? I've always had oil in a lot of the areas by the bolt heads so I assume it's working it's way up the threads.
5. Best type of gasket for the valve covers?
6. I'll need to remove the "365HP" decals on the sides of each valve cover.
Any recommendations on the best method? Using a sharp knife or razor blade would make me concerned about gouging or scratching the aluminum.
Sorry, i'm sure for the vast majority of you these are simple and real "newbie" questions but I want to do it right and not end up with scratches on the covers or leaks on the intake. Besides, since this is my first time pulling these items off I might as well learn the proper and correct way the first time around to do it and reinstall them.
As always, thanks a lot for any help. It's always GREATLY appreciated.
