Quick Oil Temperature sensor question..
  • Thread starter Thread starter Kevin McGrade
K
Kevin McGrade
Now that I have the correct sensor I got under the car and found where I believe it is located, Above the oil filter screwed into the block and there is a cover held by 2 screws over it. The sensor does look a bit different but I was told they sometimes change the design of these things all the time.
What threw me off that on the other side of the block is the identical sensor and cover over it, what is this????
I have a '92 coupe
Kevin, you're probably talking about the knock sensor on the passenger side of the block. ;)
_ken :w
