I took the day off yesterday and decided to spend a little of it with my car. I stole away for a quick ride to get some breakfast and when I returned to my parked car I noticed about a cup of anti-freeze under the front.
Being the paranoid type I immediately called my favorite shop to make sure they could take the car and then called AAA to get a tow.
After about 45 minutes of waiting for the truck I took a closer look (the engine had cooled sufficiently) and realized that what I had thought was the lower radiator hose was actually spillage from the overflow vent. The radiator was full and the hoses were fine. I drove to the shop and got a pressure test done which turned out okay. I put on a new cap and a new temp sender because they were needed, but didn't deal with anything else.
From what I understand this car isn't supposed to have an overflow tank or vent and I removed the one that a previous owner had bubba'd onto the car years ago (it was really a catch basin and not a true overflow tank since the contents couldn't get back in to the cooling system.) That tank had been dry for every day of the 15 years+ that I've owned this car.
So, finally getting to my questions, why would the radiator suddenly overflow?
It wasn't a particularly hot day. I've driven in much hotter weather.
I wasn't driving the car hard and only spent about 3-5 minutes on the freeway.
I just checked the oil and made sure there was sufficient oil in the pan.
The tires are fine, well inflated and so on.
The radiator is clear and clean. There are very few bent fins and no debris.
The engine temp never got above normal levels.
So why did the girl **** on the road?
